Very small coolant leak-cold start hose question
Old Jul 4, 2001 | 02:09 PM
ucbearcat's Avatar
I have a 3.1L-6Cyl-with MFI.
I have had a VERY small leak of coolant around the water pump. It isn't very noticeable-but it is there. After having driven a few miles and the car is warm-you can smell the coolant. At first I thought maybe the water pump seal was bad. But now that I am in there, I noticed a tear in one of the the 90* tubes to the throttle body. (Cold start) We replaced this hose about 1-2 months ago. Is there something causing this hose to tear like that?? Incorrect pressure or flow? I don't see anything close enough to hit it. Anyone have any suggestions??? Thanks in advance.
Old Jul 4, 2001 | 06:32 PM
Omar's Avatar
Have you tried re-tightening the hose clamps?
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 4, 2001 | 09:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Did you use hose that was rated for water/coolant ??
belive it or not, even fuel line won't last.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
