vortec heads 305/350
Old Feb 23, 2005 | 11:06 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I really need to know the difference between these 2 heads besides the intake valve size. I don't have the casting # in front of me, so make it a general statement. thanks
Old Feb 23, 2005 | 04:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Chamber size, port flow.
305's being smaller in both cases.
Old Feb 23, 2005 | 06:59 PM
Car: 83 Z28
Do you think that is purely because of the valve size? or are the ports actually smaller?
Old Feb 24, 2005 | 08:53 AM
five7kid's Avatar
From what I understand, it's not just valve size.
But, someone chimed in not too long ago that with porting work, the 305 types flow well. Of course, with 350 Vortecs, only the exhaust need work, so it sounds like you have to do a lot of work to the 305's to get them to flow as well as unworked 350's.
But, none of that is said with personal experience with either.
Old Feb 24, 2005 | 09:03 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The ones I have worked with came off a 2000 to 2002 chevy van. Forget the casting # though. Stock the intake side of the vortec 305 heads flow almost as good as the 350s. The exhaust port is the same. The ports are identical just the valve sizes are different. The 305 has 1.84 & 1.50 valves where the 350 has 1.94 & 1.50. The chambers are similar it is just missing the little protrusion on the side oposite the spark plug. Also the chamber is 58cc vs. 64. The increased compression would probably more than make up for the little loss of flow.
I helped a buddy drill steam holes in a set and put them on a 400 in a late 70s 4x4 truck. We also stuck in a comp xtreme 4x4 cam in it. It could spin all 4 tires from a dead stop. Engine pulls easily to 5,000 so flow couldn't be too bad.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
