Wonder bar
Old Jul 3, 2001 | 11:11 AM
NHcamaro's Avatar
Wonder bar
What exactly is a wonder bar? whats it do for you ?
Old Jul 3, 2001 | 01:02 PM
Vader's Avatar
It is a brace that bolts to the lower sides of the front subframes to increase the stiffness of the front end. Eliminating the flex in the front end can be done a little more effectively with a strut tower brace bolted across the tops of the upper strut mounts. The down side of the STB is the space it takes and the inaccessibility of some components while it's in place. They are easy to remove for routine service, however.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 3, 2001 | 01:38 PM
NHcamaro's Avatar
Oh yeah I get ya. I saw that on a RS once I was wondering what that was. thanks
Old Jul 3, 2001 | 01:47 PM
irocbsa's Avatar
Supposed to help brace the steering box brace as well, but it doesn't work that as good as it should. A lot of cars with the wonder bar still develop cracks in that area.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 3, 2001 | 05:28 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Wonder Bar
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited July 03, 2001).]
Old Jul 3, 2001 | 10:28 PM
NHcamaro's Avatar
ok after seeing that picture I guess that isn't what I saw on the RS. The RS had these 2 bars that went from one side of the engine to the other. What was that ?
Old Jul 3, 2001 | 10:32 PM
Vader's Avatar
If you saw it on top of the engine, it is the strut tower brace I referred to earlier (STB). It is a little more effective in rigidizing the front end, but the theory is similar.
Later,
Vader
Old Jul 5, 2001 | 01:31 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Where can you get a Wonder Bar? Is there a place online to order one? And how much do they cost?
Old Jul 5, 2001 | 02:49 AM
Jza's Avatar
Jza
PN# GM-14079634; Mine was $39 from a Chevy dealer. Global West also sells a beefier version for not much more.
Old Jul 5, 2001 | 04:00 AM
JoshDT91's Avatar
Engine: 2.8L V6
JZA:
So does this GM part # include everything? I can get it for about $20 on www.gmpartsdirect.com
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
Old Jul 5, 2001 | 04:32 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
hell I didnt know what a wonder bar was, but I sure as hell know what a wonder BRA is!! oh excuse me powers that be, happy 4th of july!!
http://www.wonderbra.com
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old Jul 6, 2001 | 02:01 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
ttt
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
