Car Missing....w/in
Old Jul 4, 2001 | 08:24 PM
GTAKeith's Avatar
Car Missing....w/in
I have had a problem with my car ever since rebuilding the engine...The car is a 1987 GTA. It has a 355 with TPI modified base slp runners, supercharger, cam, exhaust, and a lot of other stuff unrelated to engine miss. The problem is that it does not happen all of the time.
I have replaced cap rotor, wiires, coil and nothing makes the problem go away. I GET NO CODES. When it happens the engine misses and the tack needle seems to jump sparattically...
The info that I can tell you is below.
No Trouble codes.
Fuel Pressure is GOOD.
IAC is good
TPS is good
Ignition module is good
Plugs look good.
I bypassed the supercharger and it ran the same.
MAF is good
My only even remote guesses is that my alternator is bad or ECU is bad. I would think that if a wire was missing or shorted that a Code would appear....Plus some times the car runs perfect. It would be a lot easier to track down if it was bad all the time. If anyone has any ideas please reply or shoot me an e-mail.
Old Jul 4, 2001 | 08:33 PM
GTAKeith's Avatar
One thing I forgot....The reason I said I think the alternator could be causing this is because when I start the car it squeals....When it squeals the voltage stays low like 10-11 volts...If I tach it up the squeak goes away and then the voltage goes to 14 which is where it always was...While I rewalize that is a problem I CANT see how this would cause a MISS like this...at like 2500-3000 and up it misses all over the place..If its out on the road and I take off very solw it WONT miss,,,
Old Jul 5, 2001 | 03:29 PM
Blockhead's Avatar
I think it is bad karma. Sending money to someone and writing Skoal in the memo line.
Good luck.
Yea .... but it's gonna to the big adios in a BLAZE a glory....
Director of Darwin Awards @ www.thirdgen.org
Old Jul 5, 2001 | 03:33 PM
Bill87GN's Avatar
Umm Keith , what about after 3000rpm? May be the alt and you're not getting enough juice to the fuel pump etc? What's the voltage at the pump? Just a quick thought...I'll think more later, it's starting to hurt.
-Bill
-=1987 Buick Grand National=-
Almost Jacked Up Like a Mother
*CC 218/218 cam, ported and polished heads (1.77, 1.50), Accufab AFPR, custom 3" DP by Custom Tubes, dual 2.5" exhaust, Bilsteins, Walbro 307 hotwired, Big Mouth cold air intake, 009s (42.5# injectors), custom PROM and 20psi of fury*
SOON to have alcohol injection
Wanna try me?
-=ICON Motorsports=-
Modertor TPI board
Old Jul 5, 2001 | 07:36 PM
GTAKeith's Avatar
Well after 3000 it still misses....I dont know I guess Im going to have to start tearing it back apart...Oh yeah BTW it runs at 13.9 volts....
Old Jul 6, 2001 | 09:46 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
To get the squeak to go away make sure your belts are tight and that they don't need replacing.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
