Engine backfiring and loss of power
Engine: 305 5.0L F engine code
Here's the story yesterday I removed all of the smog equipment and I capped the hose going to the cat. And then after that it started backfiring every once in a while and there is a lack in power. Also, it vibrates like hell. What are you're suggestions. I replaced the egr valve about six months ago so it shoudn't be that. I checked all the wires to make sure they are tight.
Car: 4
Engine: 6
Transmission: 5
Sound like a loose or defective spark plug wire, or broken spark plug, or 2 plug wires swapped.
Look over everything you touched. Odds are, there's a mistake in there somewhere (in addition to the mistake of your actual task).
Car: 4
Engine: 6
Transmission: 5
That would do it....
I learned a long time ago, that if something worked before I touched it and it's screwed up afterwards, I probably did something wrong. As humbling as it may be to admit to myself that I might make a mistake, it's still the first exercise I go through, when something like that happens.
theshackle
Sep 17, 2020 08:26 AM
