Another 305 lg4 project
Old Feb 26, 2005 | 03:11 AM
84camaroZ's Avatar
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
I know this question can be answered if i looked around long enough, but please understand i dont have time. I am in Iraq right now and get little internet time. Im going to buy as much as i can while im out here so i can put it on when i get home. these are the parts im looking to get.
edlebrock performer intake, carb (600), cam kit
hooker headers
catco cat
flowmaster exhaust
Thats the start, morewill come. What do yall think? Any suggestions are welcome. BTW Its a stock 84 z28 LG4 auto trans. Thanks for the help.
Old Feb 26, 2005 | 07:05 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Rebuild stock Q-jet if still computer controlled
Call Comp Cams for cam recommendation (xtreme energy?)
Used/takeoff ZZ4 crate motor intake
Old Feb 26, 2005 | 07:46 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Yeah, save the money on the edelbrock stuff and get some gears and a posi carrier for your rear (or a whole rear) at the bone yard. I would go with the comp xe262.
Old Feb 26, 2005 | 08:33 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
pick up a "b-stall" converter. it is the stock converter for 88-92ish vettes. it has a 1800-2000 rpm stall and it will help more than you think.
stay away from edelbrock, get the holley street dominator intake and a 600cfm 4150 series vacuum secondary carb. the xe262 would be an excellent cam
www.cardomain.com/id/mw66nova for specs on my setup.
Old Feb 27, 2005 | 12:18 PM
84camaroZ's Avatar
Engine: LG4
Got it, no edlebrock. Thanks for letting me know before I dropped the cash. Will everything listed bolt right on or will I have to do any mods? I read that the flowmaster cat back kit for later camaro will fit mine with little mods is this true or is there an easier way to go about it? thanks again for the help.
Old Feb 27, 2005 | 02:24 PM
mw66nova's Avatar
Engine: 7.0L
i'm assuming your talking about the 86-92 flowmaster catback, yes, it will work nicely.
Old Feb 27, 2005 | 02:28 PM
mw66nova's Avatar
Engine: 7.0L
everything should bolt right on without issues, the only thing that might be an issue is changing your stall converter. that is definitely a two person job. you have to drop the tranny in order to do it. if you are interested in doing a converter swap, i will have one of those b-stall converters available in a bout a month. should have no more than 5k on it and i will take $100 shipped.
you may also be interested in changing you gears, i would suggest a 3.73 gear with that setup. that and the converter will really wake up even your stock motor. but with the headers/cam/intake/carb/gears/stall, your looking at an easily built high 13 second car with great street manners.
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
ambainb
Aug 29, 2015 12:43 AM
