Throws TPS code, TPS has been changed and still throws code...
Car: 1991 Conv. Camaro
Engine: V8 - 305 TBI
hey guys,
hopefully you can help me solve this mystery. its throwing a tps code, so i went and bought a new one, reset the computer and it is still throwing the same darn thing! any suggestions?
Car: 1991 Chevy Camaro
Engine: 305 TBI
Just to add to what onebinky suggested, did you adjust the new TPS? It should be 0.54 volts-0.75 volts with the throttle closed and over 4.5 volts with the throttle all the way open. There is a technical article on adjusting it: https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Which TPS code is it setting?
I have done both, checked to makes sure all the wires from the ECM to the TPS were grounded, etc. and cross ref. with a similar vehicle to make sure the TPS was set correctly. Readings come out A O.K. Would something else cause the ECM to throw the code?
What was the resistance on the reference, signal, and ground wires?
How much voltage did they drop across the wire?
What voltage reading did you have at the reference wire and the signal wire?
mdtoren
Aug 16, 2015 05:45 PM
