Fuel pressure problem
Old Jul 6, 2001 | 05:15 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
After installing the super ram on a tpi 350, I'm having problems with the car running. I have an AFPR and I'm getting 40 psi while cranking the engine and when I stop the pressure gradually goes down, eventually to zero. I'm thinking that the engine could be flooded, because when the gauge was first hooked up It was showing 65-70 psi, while cranking. What is the psi supposed to show while cranking the engine? And should it drop after turning the ignition off? Another problem I have is that the little vacuum nipple on the regulator broke off and I don't know if this would effect the car running or not?
Old Jul 7, 2001 | 12:44 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Nevermind, guys. I think I temporarily flooded the engine, but now it's starting again.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
