coolant fan switch works if tapped on
Old Jul 7, 2001 | 12:17 PM
speedlvr's Avatar
I had a loose connection on the switch so I fixed that and the fan still didn't come on until I tapped on the switch itself. What is it inside the switch that makes it work? Are there any moving parts that can get sticky?
Old Jul 7, 2001 | 01:19 PM
iroc5speed's Avatar
I don't think there are moving parts. Are you refering to the connector on top of the thermostat housing? If so, I'm having the same problem, and I had to go buy a new connector from GM, it was $20. Probably a good investment, so you don't overheat your engine so you don't have to buy a new one.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
The_Phoenix
Feb 4, 2016 07:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
