power window motor prob.....help urgent
Old Jul 7, 2001 | 11:47 AM
jmon92conv's Avatar
i am replacing the power window motor in the drivers door. I have the motor in, and a large coiled spring feel out. where does it go? Also is there any tricks to get the motor to mesh with the sproket? I am having trouble with it also. Bloody handed Sat., windows suck
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Jul 7, 2001 | 12:24 PM
fbodfreek's Avatar
Car: 1990 Camaro Iroc-Z Convertible
Transmission: Automatic
Good luck man, I put mine in myself and it was a PITA!! I hope you have a buddy helping. The "scissors" mechanism that assists in raising and lowering the window is spring loaded, so it could be part of that. On my '91, I just moved everything forward to the front bottom of the door where I could drill out the rivets that hold the motor on the "scissors" mechanism, then installed the motor.
Old Jul 7, 2001 | 12:27 PM
jmon92conv's Avatar
I hacked a bigger hole to get my hand in at the lower front corner. The damn spring is what complexes me. I am doing it by myself, which only adds to the heartache. Any other suggestions are welcome.
Jeremy
Old Jul 7, 2001 | 12:31 PM
fbodfreek's Avatar
Oh, and before I removed it, I put a nut & bolt with large washers on it in there to keep everything in place. (once you remove the motor the "scissors" will have no resistance against that spring, so you could in fact hack a finger off if you're not careful. I believe there's a tech article on doing this.)
https://www.thirdgen.org/newdesign/t...rwindows.shtml
[This message has been edited by fbodfreek (edited July 07, 2001).]
Old Jul 7, 2001 | 04:01 PM
jmon92conv's Avatar
Thanks guys, but how do you get the spring back on?
jeremy
Old Jul 7, 2001 | 06:27 PM
jmon92conv's Avatar
F*** This!!! I am sending it to the mechanic.
Jeremy
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
