305 Cam Question...Please Help
Old Feb 28, 2005 | 10:11 AM
camaro305t5's Avatar
Car: 1984 Chevy Camaro
I know, search the forums, everyone asks this question.
Well, I have a special situation,
I have a 305 that had a electronically controlled carb, but now it's standard controlled carb, with a standard HEI distributor. I have dynomax headers, exhuast, and a 5 speed tranny. What cam should I run? I want something that I can daily drive, but has a sweet sound and idles OK, it doesn't have to be perfect. I want to gain some power. Also, should I replace the springs as well? I don't want to do any head work, though.
Thanks,
Sage
Old Feb 28, 2005 | 11:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try a Comp XE262H. DEFINITELY put the right valve springs on it. Consider getting rid of the factory rubber rocker arms while you're at it. A set of Comp 1412s would be about perfect for that cam and an otherwise untouched motor, for not too much $$$.
Old Mar 1, 2005 | 11:53 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I love my COMP XE-262. Coupled with my ported 416 heads, the car runs a lot stronger. I also added a COMP double roller timing chain (came with k-kit), new pushrods and the COMP rockers that RB listed.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
