LO3 typical oil pressure
Old Jul 8, 2001 | 03:22 AM
colincamaro's Avatar
My 89 RS LO3 305 TBI when warm runs at only 25 or so psi[according to the gauge] at 60 mph is this normal, It seems a little low?
Old Jul 8, 2001 | 09:35 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
The oil pressure gauge on my LO3 is about 40 at idle. After it warms up; at cruise speed it's always pegged at 60 or whatever the highest number is. Then at idle it's like 50. I think my guage might be on the fritz though. It seems to be working though.
Old Jul 8, 2001 | 11:04 AM
irocbsa's Avatar
Change your oil pressure sending unit. It might have gone on the fritz. They have a tendency to do that on our cars. If you just want peace of mind, check the oil pressure with a mechanical gauge. You can pick one up at most auto parts stores.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
