Gas out TBI?
Old Jul 7, 2001 | 09:21 PM
pookey's Avatar
Gas out TBI?
Going to try to explain this as best as possible. On my drivers side TBI, where the linkage for the throtel (spelled right?) goes into the TBI, I am getting gas leaking out of it. Am I right or is it coming from higher up. Need help urgetnt please!
88 White Formula 305 TBI With A New CD Stereo and Abolutly Nothing Else Done To It!
Old Jul 8, 2001 | 09:24 AM
Enkil's Avatar
Throttle.
And the only place gas SHOULD be coming out of is of course the injectors.. Check to see if there's any cracks in the metal, which would really really suck... Hopefully though you just have a bad gasket somewhere.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 8, 2001 | 11:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sometimes gasoline can leak around the throttle shaft, especially if it's worn. A small amount of leakage is somewhat normal.
ICON Motorsports
Old Jul 8, 2001 | 01:49 PM
pookey's Avatar
Would this cause the car not to start though? It cranks but does not turn over.
Old Jul 8, 2001 | 09:16 PM
pookey's Avatar
The car started fine today and no gas was leaking from the TBI. Must be one of those things.
Old Jul 9, 2001 | 03:33 AM
pookey's Avatar
Hey ede, Karps TA, Vader, you can close this post, I got the car started. Thanks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
TBRays98
Sep 6, 2015 05:05 PM
86iroczwv
Sep 3, 2015 06:21 PM
