New mini starter - which one?
Old Mar 2, 2005 | 04:40 AM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
Hey all, my starter is finally deciding to die on me ya know, gotta thwak it with the hammer a few times and it'll work lol.
Anyways, I'm looking into a new starter and given future upgrades, weight loss, etc, am looking at getting a mini starter.
I've read many good reviews on many, and am looking at getting a CSR, just wanted peoples opinions for other starters etc. I would prefer to spend a little less, but we'll see if want gives into need. Anyways, thanks for the opinions, as always, I appreciate it!
Engine/tranny is all stock, minus plugs, sparks, CAI, and exhaust, with headers coming soon.
Also, which starter would you recommend of the CSR's and other brands? thanks again
Old Mar 2, 2005 | 07:36 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I installed the Jegs p/n 555-10001 $148.99 last year and it's worked great to date.
Old Mar 2, 2005 | 09:45 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have the CVR starter, part number 5323. I love mine.
Old Mar 2, 2005 | 04:29 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I installed the Gm performance parts mini starter for the zz4 motor. it bolted right up but i had to shim(included in box) the starter motor away from the mount.
Old Mar 2, 2005 | 04:40 PM
Durango_Boy's Avatar
Car: '98 Durango, '77 Vette
I also have bee considereing using a mini starter, but didn't know where to begin looking. I'm building a 400 though, not a 350. Am I understanding correctly that it will fit my block? Also, how do you know you need to shim the starter, and by how much? Thanks guys...
Old Mar 2, 2005 | 05:00 PM
tommyt's Avatar
Car: 87 T/A
Engine: built NOS 350
Transmission: manual 700r4
For a 400 You will need a staggered bolt mount starter.
Your starter is OK if You have 1/8" clearence between the
flexplate gear and the shaft that holds the starter drive gear...If its less, You need shims. If it is more, You need to machine the starter mounting surface (this happens pretty rarely) Most of the time You will either be OK or need shims.
Old Mar 2, 2005 | 05:15 PM
IHI's Avatar
IHI
Best way to check for proper starter gear/flywheel mesh is to get a standard paper clip, use a screw driver tyo pry out the starter gear and stick a portion of the paper clip between the starter gear and flywheel, the paper clip should just fit between the two.
if it's too tight, install a shim and try again.
Old Mar 3, 2005 | 04:25 AM
Car: 1987 GTA :)
Transmission: Stock
Good info so far!
Glad for the replies so far! I've also heard you can use an LT1 starter for the cars, and pros or cons about those? Thanks!
I think (depending on the next paycheck lol) if I can I'd still like to get the CSR, but otherwise I'm leaning towards the Jegs (555-10001) or the LT1 if my research is correct in that it's usable (again, stock 87 350 TPI). Which one would you guys recommend?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
