buring oil? i think
Old Jul 10, 2001 | 09:04 AM
85witetrannyam's Avatar
buring oil? i think
when i start my car in the mouring it starts up right away and it smokes a lil bit.after ive drove it for a lil while i have to litterly like pump the gas pedal to start it.and gradually my oil level is dropping.could this have something to do with my cars hard starting problem and if so.is there a way to tell the difference between oil goin the rings or valve seals????????????????
Old Jul 10, 2001 | 10:30 AM
ATOMonkey's Avatar
The puff of smoke when you first start in the morning is bad valve seals, which is a common problem with sb chevys. Replacement parts can be found at NAPA they will (or should) sell you O-rings, positive seals, and plastic "umbrellas." Cost is less than $50 as far as I can remember.
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 10, 2001 | 12:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hard starting due to an over-rich condition and oil use can be related. Gas can dilute the oil, making it easier to get past the rings and valve seals.
Like ATO says, though, valve seals do get hard on SBC's, and aren't that expensive to replace if you have an air compressor. The valve spring compressor, spark plug hole air adapter fitting, valve cover gaskets and seals all together should cost you in the neighborhood of $50.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
