How do I get rid of carbon?? w/n
I have my motor apart, and I have the valves out of the head, what is the best way to get the carbon off the valves, is there and solvent that "eats" carbon??
Car: yep
Engine: uhuh
Transmission: sure does
Wire wheel on a bench grinder.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Easy Off - hell yeah!!......
Thorough rinsing is in order when used though.........
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Hotchkis STB.
We use Easy Off at work. Yellow can that looks liek spray paint. Just spritz a bit on the blackness and watch it foam away. That stuff will make you retarded if you inahle it. Definitely not a cool high. I threw up once at work because the fumes got to me, and i went outside for fresh air and it was 90+ degrees outside :P
1992 Pontiac Firebird
- 305ci V8 TBI / Automatic Trans / Loaded
- MODS: Edelbrock 14x3 Open Element Air Cleaner, Dual outlet exhaust
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by 87RS402:
Look under the kitchen sink... If it's not there ask a woman.</font>
(What does it say about me that I knew it was oven cleaner?)
Follow directions on can, meaning use only in well ventilated oven, er, area.
