Removing Belts = How much HP?
Old Jul 10, 2001 | 02:28 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
My AC is out of Freeon, so I removed the belt to save wear and tear on the compressor. I know it frees up SOME HP but how much about? Then How does one go about disabling the Smog Pump? Just un belt it, or is there something else you have to do.
Old Jul 10, 2001 | 02:42 PM
rezinn's Avatar
You can just take the belt off..but if it is legal, you might as well take out all of the smog equipment.
I don't know exactly how much power removing any accessory will free up, but it probably isn't in the double digits.
Old Jul 10, 2001 | 05:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only "right" way to remove the smog pump is to remove it completely and plug up the A.I.R. ports in the exhaust manifold. If you just take off the belt, exhaust gases will get into the pump an seize it up (ask me how I know this).
As for power, neither a free-wheeling AC pulley nor the A.I.R. pump uses appreciable power. I kept track of my ETs last year before and after these removals. The biggest gain from removing the AC was the weight loss, not just removing the belt. No difference after taking off the smog pump belt, but now I have to get it fixed before emissions testing next month.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited July 10, 2001).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
