"x" on my rods? and what cam?
Old Mar 5, 2005 | 01:40 AM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
I just took apart a 350 i purchased for a 100 bucks(has a slightly bent valve, and it has 441 casting heads, flat top pistons, 4 bolt mains, and the rods have x's next to each of the rod bolts. now are these factory rods or are they anything special? it also has a cam in the car and i cant seem to find info on it is it says "SR" and "119306" with "3434" and some other lightly printed numbers like "2006" and it has the date "11-22-00". any info on these items would be nice.
Old Mar 5, 2005 | 06:20 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
The "x" rods are a heavy duty factory rod. Usually in truck motors. I have a set of these in my 406. These are almost as good as the famous sbc "pink" rods. 441 casting heads are 76cc 194 intake
150 exhaust heads I believe. Sounds like a great deal for the money. No clue on the camshaft. Hope this helps....
Old Mar 7, 2005 | 04:58 AM
Night rider327's Avatar
Car: 1988 Camaro
Like likeenz24 said they are "heavy duty" rods. The well known "pink" rods was the same X rod castings, but with alittle extra work done to them, like shot peened, magnfluxed, etc.
The X rods are the strongest and truest chevy rod casting, but like all stock rods they still have 1 weak spot. The rod bolts. Not saying it's bad or anything, but just a known and proven fact. GM was cheap when it came to the steel used to make thier bolts!. They are fine in most useages. I would just limit stock rod bolts to about 5500 rpm max though
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
z28guy134
Sep 1, 2015 11:50 PM
