Need help before I go to strip....no 1st gear in drive????
Old Jul 10, 2001 | 11:11 AM
CamaroX84's Avatar
Well, I'm going to the track tonight for my first run with the new motor. I just got a pair of slicks so I decided to try them out today. I also just put a TransGo shift kit in the 700R4 on Saturday. I noticed that ever since the shift kit, drive and overdrive have been a little funky. It seems like I have no 1st gear. When I shift it down to 1, I have no problem getting the slicks to squeal. But, in drive and overdrive, I can't do it. It's only been doing this since I put in the shift kit. What could be wrong? Could it be the TV cable? It also seems that under easy acceleration, it doesn't shift until too high of an RPM. Could these problems be related? ANY help would be greatly appreciated. I want to get this fixed before I take it to the track. Thanks in advance.
1984 Camaro Sport Coupe - 73K Miles, Rebuilt 355 TPI L98, Crane 2032 CompuCam - 214/220 @ .050", Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Disc Brake Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
New Paint
Best 1/4 Mile Run (with old LG4 motor):
16.760 @ 80.74 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Old Jul 10, 2001 | 03:06 PM
CamaroX84's Avatar
Oh yeah, i think it starts off in first but shifts right away, because at a dead stop I can shift it down to 1 and I don't feel a change in gears. Is it the TV cable? Thanks.
Old Jul 10, 2001 | 04:20 PM
Grand Prix's Avatar
A loose TV cable can cause the shifts to hold over too far. GM transmissions tend to hate 1st gear, and dislike 2nd a little. So in drive or overdrive it may not be easy to get the transmission to shift back down to 1st if its already in another gear. Check out the TV cable first. It has a very surprising effect on the transmission's operation.
Old Jul 11, 2001 | 01:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Plus, the line pressure (what the TV cable controls) is nearly doubled when the shifter's in "1st" or "2nd". That extra line pressure might be making up for a poorly adjusted TV cable... but be sure- you probably don't want to break halfway down the track!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
