8Mike9 And Others help with codes
Old Jul 10, 2001 | 06:59 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well you will not believe this I used AJ's mthod to check the pickup and its fine. Now there is no trouble code at all........I have done nothing but raise the Fuel pressure a little. It seem still VERY low on Power it feels like 150 HP. out of 325hp
Here is the scan results
@58 MPh at 1775 RPM
Idle air = 78 steps
Cooland temp 185*
Map = 2.07
TPS=1.13 volts
integrator= 114 (i don't know what this is)
Oxygen sensor= 431 mvolts
KNOCK 2
Rich lean flag= Lean (but goes rich when I get on it a little)
Thanks everybody for the help I just can't tell if these numbers are good or bad!!
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jul 11, 2001 | 01:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Brian,
Looks like you're making some progress.
I'd surmise that when you checked the PU coil, I'm assuming you unplugged it from the ICM and tested continuity? If so, when you reconnected it you may have cleaned the connection that was intermittantly causing the Code 42.
I also noticed you your knock counts have decreased, but are still present...proably pulling out some advance as well, losing you power.
Have you talked with FastChips about your setup, and where initial timing should be?
The increase in fuel pressure could be overcoming a lean condition causing the knock as well, but from your last post, your rich/lean flag as well as the O2 sensor mv's indicated you were okay at cruise (at that time) and not lean. Did you check the O2 cross counts? This is important to see if the settings in the Chip are trying to controll cruise A/F atio properly.
See, if you are in fact running lean at cruise, and rich at WOT, there's nothing you can do with the FPR to compensate, it will HAVE to be done in the Chip, no way arround it, other option is to use larger injectors, and less pressure.
This assumes that you don't have a lean condition causing the knock counts, that adding more fuel is masking over.
So again, my suggestion is to verify with FastChips what they recommend for the basetiming and then verify you're O2 crosscounts are in the neighborhood of 10 or 12.
BTW, I've forgotten the all the aspects of the intergrator and would have to look at my scantool manual for verification, you may get a faster respsponse from the PROM Board for that particular question.
[This message has been edited by 8Mike9 (edited July 11, 2001).]
Old Jul 11, 2001 | 02:11 PM
Thanks so much.....
Brian
1989 Camaro RS
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
