How do I set the timing ???
Old Jul 11, 2001 | 09:49 PM
smurfmobile's Avatar
ok here's my problem... I just swapped from 305 LG4 to a built up 355...
in the process I removed both distributors and didn't mark anything so I have no idea how it's supposed to go back in...
so...
after I preoil the engine , I want to drop in the distributor but I have no idea how to get close to the timing that I want.
I heard about removing #1 spark plug , turning the engine by hand (well not by hand , but ya know what I mean , by the way , do I use the big center bolt on the crank pulley ? I think I'm right....) and when see the #1 piston get to the "top" I do something or other...
so as you can see I don't really know what to do but I Think I get the basic concept... can someone point me in the right direction ? maybe a tech article or something like that ?
also , is it ok to turn the engine by hand before I preoil it ? (I just ordered the oil primer tool from jegs)
now I think that the process I described above will get me somewhat right timing...
so I guess I should also pickup a timing gun to do the final adjustments, right ?
thank you for your help , I really appreciate it
Old Jul 11, 2001 | 11:36 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
hey man..
you're in luck, I wrote a couple of pretty ogod tech articles on how to set your timing
www.IROC-Z.org/tech
you can check out my "installing your distributor" article and "setting your timing" article..
i do it slightly different than alot of people so if you have any questsions, EMAIL ME. i learned the hard way how not to set your timing i give you a couple of tricks that will save you time and alot of frustration..
my email address is admin@IROC-Z.org
let me know if you either liked the articles or didn't find them useful so i can rewrite them if needed..
talk to you later,
Colin
Webmaster: www.IROC-Z.org
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
