Need help fan not working??Where is switch.
Old Jul 11, 2001 | 03:23 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
My fan hasn't been working on my 86 TPI which used to be a 305 it is now a 350. Now there is no switch on the passenger side except the knock sensor however there is one on the drivers side between the first and second plugs. It has a slip on connector that just slides over the top of this pin like connector. Is that the fan switch???
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old Jul 11, 2001 | 03:28 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
no, that's the temperature switch for your gauges..
you might want to chagne your coolant temp sensor, located on the front of the intake manifold next to a square plug..
Webmaster: www.IROC-Z.org
Old Jul 12, 2001 | 02:00 PM
KustomIroc's Avatar
Engine: 383 Stroker
Is that where the fan switch is?
Jamie James
1986 Iroc-Z 305 TPI
My IROC:
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
