Getting spark plugs "in-line" = 25% increase in power???? WTF????
Old Jul 12, 2001 | 12:07 AM
CamaroX84's Avatar
I was talking to this guy I know today. And he was talking about something (I can't remember what cuz it sounded like bull****) with the spark plugs. He said something about getting them all "in line" would net a 25% increase in HP. What is he talking about? I know he is BSing with the 25% increase, but what are "in line" spark plugs. He mentioned something about the spacer on the plug. Thanks.
Old Jul 12, 2001 | 12:10 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
He's talking about "indexing" the plugs, I serously doubt 25% increase in power...maybe, .25% increase...maybe.
But for all the work it'd be to index plugs on an F-body (assuming you have stock exhaust manifolds), I'd just leave the spare out in a race
Old Jul 12, 2001 | 01:44 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i would tend to think you would only notice indexing on the plugs if you were in some type of serious racing where all of the cars have the same specs (NASCAR, open track) and 4-5 horsepower can mean hundredths of seconds around a track..
in town it would be a waste of time to index, imo..
and those platinum +4 plugs, or the splitfires, total waste of cash.. get a standard platinum or stay with an AC R43TS or something similar...
Webmaster: www.IROC-Z.org
Old Jul 12, 2001 | 10:54 AM
82camaro's Avatar
Car: 82 camaro SC
It's a very small percentage. The percentage depends on how far from 'in-line' the plugs were already. If most of the plugs were already 'in-line' before the indexing, you would see no gain. If all the plugs were not 'in-line' you would see a small percentage gain. The a high HP engine the small percentage translates into a small power gain. In a street car it's a waste of time, IMO.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 12, 2001 | 08:20 PM
El Guapo's Avatar
In case you dont know, "Line-up" "indexing" means having the flame part of the spark plug facing the cylinder bore as much as possible. You make a mark indicating where the "arm" is, which is where it would be in the way then turn the plug till that mark is pointing right where you want it. The spacer is so that if you dont get the right torque, you can put a spacer on there to help get the plugs tight.
Hope this helps
Clayton
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
