crane cams Z cam
Old Mar 9, 2005 | 12:29 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
crane cams Z cam
anyone check out these new Z cams?
how well will these work with a TPI motor?
113521 cam is one im particularly interested in,
459/486 int/exh with a 268/280 duration @ .050 and a 112* lobe sep.
only problem is, in the zcam description they have flat tappet and roller cams, but in the guide , they dont specify which cams are what.
Old Mar 9, 2005 | 01:03 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd say they are about equivalent to the Comp cams Extreme grinds. Sounds exactly like the XE268.
For a TPI you want something with a larger lobe seperation, around 112-114 with reduced overlap.
I'd say just go with on of the Comp Extreme TPI computer controlled cams. It will work the best.
Old Mar 9, 2005 | 07:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
the zcam is rated 1800-5800rpm though while the xtreme energy is 1500-5200rpm. and since my intake is gonna be the stealthram, i want that extra bit of rpm.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
