what do i have?
Old Mar 9, 2005 | 12:15 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
what do i have?
just a quick question:
i have a 88 firebird 2.8 mpfi, auto. w/overdrive. does anyone know what transmission and gears i have...it has disc brakes in the front and drums in the rear...if that helps. thanks.
Old Mar 9, 2005 | 12:35 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
You have a 700R4 transmission and most likely 3.42 gears out back. I'm not real sure on the gears as I'm not that familiar with V6 F-body's.
Is there still a facatory tag on your rear-end housing? If there is, decoding that lettering will tell exactly what gears you have. Also you might ask around on the V6 board.
Old Mar 10, 2005 | 11:34 PM
eagle_eyes's Avatar
Engine: '93 LT1
ok, thanks for the help.
Old Mar 11, 2005 | 08:32 AM
Jade Grey's Avatar
Engine: 305TPI
If your RPO tag is still intact one of the code correlates to your rear-end gear ratio. The RPO decoder on this site is still down however. Look for a GU2, GU4, or GU6. Are complete list of GM's RPO codes can be found here.
For 1988, the possible axle tags for non-posi rears are 6HP, 6HK, and 6HL. The tag is located on the right axle tube on the forward side.
Old Mar 11, 2005 | 10:21 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Jade Grey: is it really a 700R4 transmission? I thought those were for V8s? I have an 89 V6 firebird that I'm parting out and want to sell my transmission but I'm not sure what model it is. I'm not doubting you as I have no knowledge about these things, I just want to make sure thats correct before I post it for sale. Any ideas on a value?
Old Mar 11, 2005 | 11:09 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
look for a cast in stamp on the housing that reads "MD8". If it has that then its a 700R4
Old Mar 11, 2005 | 12:23 PM
Car: 86 T/A
Engine: HSR 355
So it could hold up to a V8 engine? I was looking at doing an engine swap but the mechanic said the tranny would have to go too because the V6 trannies wouldn't handle the power (he didn't look at the tranny itself).
Old Mar 11, 2005 | 12:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
V6 and V8 tranny's are different, but are both 700-r4's. The only automatic transmission that came after 1983 in F-bodys was the 700-r4
Old Mar 11, 2005 | 12:55 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
It's not that it won't handle the power, a V6 trans won't bolt up to the V8 engine. Bolt hole pattern is different.
