Corvette L98
Corvette L98
I'm gonna get a covette 89 l98 complete engine. I was wondering if my 91 TPI will bolt onto the l98 heads. I know that the EGR will no longer exsist, i just need to know if the bottom part of the 91 plenum will bolt to the 89 aluminum heads. I want to keep my SD, then sell the mass air.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
I change the 1LE because it is too slow and is no longer origional anyways... somebody swaped the 12 inch front brakes before i got the car and its been in 4 accidents. The 5.slow is to slow. So do i just redrill holes for the vette intake, or do i just widen the ones that are already there?
<font face="Verdana, Arial" size="2">Originally posted by madmax:
The 91 base wont bolt to the vette aluminum heads as is, but that can be remedied with some machine work... even a drill will work for that. Beyond that, it will work fine.</font>
Also, since you are in Lake Oswego, check out the Cascade Crew board man! We need more people from Oregon in our group!
-Roshambo
[This message has been edited by Roshambo (edited July 12, 2001).]
the_hamturdler
Sep 30, 2015 12:50 PM
