87 IROC misses and hesitates, help!
Old Jul 12, 2001 | 02:04 PM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
My 87 IROC with a 305 TPI, 700R4 96K miles does this hesitation thing during slight acceleration. At about 1/4- 1/2 throttle, it sounds like it's missing, but when cruising or flooring it, it sounds fine. I replaced the spark plugs and cap and rotor, changed the fuel filter, and unbelievably, it's worse! The car is only driven about once a month; I don't know if that makes a difference. Any ideas?
Old Jul 12, 2001 | 02:32 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
try changing your EGR and changing vacuum tubing..
Webmaster: www.IROC-Z.org
Old Jul 12, 2001 | 03:43 PM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ColinOpseth:
changing vacuum tubing..</font>
Every mans worst nightmare.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Jul 12, 2001 | 06:46 PM
leirch's Avatar
The stock tpi EGR ain't crap until you have changed or attempted to reach one on a superram intake.
Brendan
Old Jul 12, 2001 | 07:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
What about your wires? It sounds like a cut/burnt wire.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Jul 12, 2001 | 07:50 PM
Engine: 305TPI
<font face="Verdana, Arial" size="2">Originally posted by Red Devil:
</font>
if it was wires it would always run bad..
Old Jul 12, 2001 | 07:52 PM
Engine: 305TPI
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
</font>
it's not 'too' bad..
it took me about 2-3 hours to do it, but i had my Dad hold the wire in the OEM shape while I heated it with a match so that all of the bends look stock...
you really have just 2 main on the pass rear of the intake, the one going from behind the EGR up to the front of the throttlebody and then the one from the TB over to the drivers side..
Old Jul 12, 2001 | 08:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
</font>
CO, I have fried too many wires on my headers, when I stomp on the gas you can't tell there is a miss, however in the lower RPM band, you will notice a miss or slight hesitation. It would be obvious only is seriously damaged or completely cut.
-Thomas Jefferson
Old Jul 13, 2001 | 01:12 AM
tommygun's Avatar
Engine: 5.7 TPI
I forgot to mention, the car only gets about 170 miles to a tank of gas, and there was black carbon buildup on the plugs. I also changed the O2 sensor.
Old Jul 13, 2001 | 04:08 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
It may be an ignition pickup coil. Sometimes they get an intermittant open... Do you have a problem of frequently changing modules?
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mhatfield 14
Oct 24, 2015 07:48 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
