Fuel Pressure Retention (non-3rd gen)
Old Jul 12, 2001 | 12:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Vehicle is '91 Bonneville 3800. Had 80k when purchased 2.5 years ago, has never retained fuel pressure when engine is shut off (don't have to relieve pressure when changing fuel filter, for instance). Replaced the fuel pump last year (was losing power when hot), runs well with new pump but was hard to start both before & after replacement. I've noticed it does not have any pressure at the rail after sitting over night or even immediately after shutting it off. I replaced the regulator (no change), it gets good mileage and otherwise runs great.
The fuel pump supposed to have a check valve, correct? Is it possible both the original and replacement pumps had bad check valves?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 12, 2001 | 10:56 PM
Guest
Guest
Posts: n/a
Yea the pump is supposed to prevent the fuel from flowing back into the tank. Anything is possible with parts, so its hard to say if thats it or not. Are the injectors possibly leaking? That or the 'new' regulator is bad.
Old Jul 13, 2001 | 01:25 AM
five7kid's Avatar
I doubt it's a problem with the injectors, as it idles & runs well once it starts, gets good gas mileage, and the fuel pressure is gone in the time it takes to turn the engine off and run up to the engine and check it. The new regulator didn't change a thing.
I didn't mention that I also changed the fuel pump relay. Would a lack of pressure when you first go to start it make it hard to start? It usually takes 3 or 4 tries, no matter how long you crank on it each time, before it starts. Really weird.
Sounds like I may be dropping the tank again. Oh, goodie!
Old Jul 13, 2001 | 07:11 AM
ede's Avatar
ede
i'd look for a leaking injector or FPR leaking off preasure. just a guess, i'm not EFI expert.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
