Help me knock a second or two off...
Old Jul 12, 2001 | 01:49 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Check out my sig for stats. I G-tech'd my car last night and got 16.1@87mph with 166rwhp. There were no pre-test mods done, and three of us were in there, adding about 600lbs(I can ditch 400lbs of that) I figure I can get into the 15's with the less weight, tuning my carb, and tweaking here and there. Any suggestions?
1986 Camaro Z28
White w/ T-tops
Tinted Rear Window
ENGINE
305 H-code
Gasket-matched heads and intake, ported and polished
Comp Cams 224 @.050
.472 lift I/E
Dual Snorkel Air Cleaner w/ K&N filter
Accel 8.8mm wires
TRANNY
700-R4 w/custom built 3000 stall converter
tranny cooler
EXHAUST
Flowtech Headers
No cat
Dynomax muffler
STEREO
Alpine CDA-855
Kenwood 4X6's, 6X9's
MTX 4240 amp
2 Sony 12" X-Plod's
Alpine 8440 alarm
Uniden 6599 Radar Detector
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Jul 12, 2001 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The mph is good for low to mid 15's. Lose all the extra weight you don't need. How much does all that stereo equipment weigh?
Traction. Gets some slicks and upgrade the rear suspension. If you want to get more HP then it's not cheap. Simple bolt-on stuff won't give you 50hp.
Easiest way to drop 1-2 seconds is NOS.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 12, 2001 | 08:28 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Hummer,
I'm assuming you have a Qjet. If so, then go to this site's tech section and do the carb and HEI ignition mods that Damon has written up. They cost next to nothing and really do make a startling difference
1986 Camaro Sports Coupe
T-tops, power hatch, third brake light
LG4 305 V8, "Damonized" Q-Jet 4bbl, K&N filter
Crane ignition kit, TH700R4 transmission and Derale cooler
Air conditioning, pw, pl, pb, ps
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
Old Jul 13, 2001 | 10:39 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
By losing the passengers (400 lbs) you will drop about .4 off your 1/4 mile time.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Exhaust
"There is nothing more addicting than speed"
Old Jul 13, 2001 | 11:51 AM
ATOMonkey's Avatar
Rear Gears my friend. I assume you have 3.42's? Finish up at redline. That should knock quite a bit of time off. Run without accessories(good for about 40 ft-lbs if you still have all of the AC SMOG etc.) Headers always help a sbc run better due to the siamesed exhaust. Advance ign timing to about 8* BTDC from 0*. Don't try running high octane it burns slower and will slow you down, and if you hear pinging retard back a couple of degrees. If you have an open diff then try launching with the car slightly angled to the right. Straighten it out as you launch and it puts more weight on the right side tire. See some of the other posts about LCA's and torque arms to further help you. That 5.0 should run 13's without cracking a valve cover.
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 13, 2001 | 12:03 PM
Bort62's Avatar
Lol, 13's w/o cracking a valve cover... right...
I HOPE to be running High 13's with my Cam, Intake, SLP headers, 3.42 Posi Rear, 2400 Stall Converter, ported stock heads, and A Lot of Launching practice.
If that Cam you have is I224 E224, I think its a little big for the stock Heads.
The Comp I218 E224 Im Running is probrably a little bit large for the stock heads as it is.
The rearend you have is Probrably the stock Posi 2.73's, Wich are Not helping you at all.
lOok Into 3.42's or 3.73's, and a SLP takeoff Posi carrier ( need new axles, however )
Alot of time Can Be Picked up In just Driver sKill. Where are you shifting ? I run My best times shifting at 6 grand ironically Enough.
Looks lik eyou are using the Stock Intake, as well. Not a Great mAtch to that Fairly agressive Cam. Can't go Wrong with a performer RPM spreadbore!
Most likely, Your Lack of speed is due to Tuning and driving difficulties, Play with your Gtech and see what you can do to make it run faster.
You should be Running a LOT faster than you are, however.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jul 13, 2001 | 01:25 PM
85_ZED28's Avatar
Car: '85 Z28
HELP
I can't find Damon's carb Tech Article
1985 LG4 Z28
White w/ Grey ground effects
Red interior
K&N Chrome Element and Filter
Flowmaster 80 series muffler
Aftermarket High-Flow Cat
Chrome Edelbrock Valve Covers
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
