87' Firebird Formula w/350 TPI : RPM problems...
Old Jul 10, 2001 | 01:02 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
I have an 87' Firebird Formula w/ a 350 TPI system. The engine has about 15000 miles on it. The problem is that after about3700-4000 RPM it won't pull anymore. I have replaced the fuel pump, strainer, fuel filter, fuel preasure reg.(also installed an adjustable), plugs, wires, distributor cap & button,02 sensor and the module in the distributor(it died). One more thing, while I had it plugged into a OTC 4000 it showed that the BLM would go to 255 after driveing for a little while. The TPS and IAC are set, and the O2 count is good as well(altough it smells rich at idle). Any suggestions would be great! TIA
dgreene
'87 Firebird Formula 350 TPI, Ported Plenum, Adj. Fuel reg, gutted cat, catback exhaust, air foil, K&N air filter, chip,170 thermostat,Borg Warner Posi 9 Bolt w/ 3.23 gears....
Old Jul 10, 2001 | 09:05 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
OK. I went back and set the timing, TPS, IAC, and set the fuel preasure to 44 PSI static. I runs somewhat better(pulls real good) up until 4200 now, and then it just drops off. I'll keep trying....
dgreene
Old Jul 10, 2001 | 09:36 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
Well, I kept digging through the archives and found the answer to my own question. Thanks to anyone that read this and at least gave it some thought.
dgreene
Old Jul 10, 2001 | 09:39 PM
98_1LE's Avatar
So what was the problem? Was the fuel pressure dropping off?
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Jul 11, 2001 | 03:14 AM
Bort62's Avatar
Sounds Like YOu just have TPI
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jul 11, 2001 | 07:56 AM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
Bort62 you hit it on the head. I didn't realize that these systems had this limitation from the factory. This is the only one that I have and I didn't buy it new. I thought something was "wrong" with it. So, I guess my new question would be: What do I need to do to it to make it turn up a little more? I will be looking through the archives in the mean time and see what I find.
dgreene
Old Jul 13, 2001 | 02:36 PM
dgreene's Avatar
Car: 87 Formula 350
Transmission: 7004R
Any suggestions on the BLM going to 255?
dgreene
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
Randomtask2
Aug 13, 2015 01:57 AM
Sanjay
Aug 12, 2015 03:41 PM
