A/C compressor duty cycle?
Old Jul 12, 2001 | 09:51 PM
John Boy's Avatar
I recently did the vbelt to serp swap from tacreations and I added the r134a today. Well it works but the a/c compressor makes terrible grinding noises when its engaged, which happens to be quite often. It wants to run constantly when ideling and it runs for about 5-10 seconds then its off for only 1-2 seconds when going down the road. Can anyone shed some light on this?? Thanks.
Old Jul 13, 2001 | 10:22 AM
82camaro's Avatar
Car: 82 camaro SC
You did only install 80% of the A/C systems rated capacity of r134a, right. Too much could cause some noises and kick the high pressure switch out going down the highway. Not enough r134a could also kick the low pressure switch out going down the higway as well, but won't cause any noise.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 13, 2001 | 03:30 PM
John Boy's Avatar
I got the kit from wal-mart and used the tech article as a guide https://www.thirdgen.org/newdesign/t...ofitac.shtmle.
It would only take about half of the last can though. I'd guess about 35oz total r134a. Should I try to get the last half can in there? Thanks.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
rubyred88
Sep 17, 2015 02:19 PM
