Aftermarket radiator that fits under stock shroud?
Old Jul 10, 2001 | 05:40 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Is there one? I've heard of Griffin and Be Cool, but are there others, and do they fit unde the shroud? Thank.
Old Jul 10, 2001 | 06:02 PM
cvpde37's Avatar
That's about the only two I've heard of. I have the BeCool. Expensive as he!!, but well worth it for the great cooling help. 98 degrees with high humidity the other day and still never went over 175 degrees.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Jul 10, 2001 | 08:23 PM
Scott_92RS's Avatar
Car: 1992 RS
Does it fit under the stock radiator shroud?
Old Jul 10, 2001 | 08:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any 19x31 GM style rad will fit. A 4 core may need a little modifications to work.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 10, 2001 | 08:35 PM
Scott_92RS's Avatar
Car: 1992 RS
What kind of modifications are we talking about? cutting a bit of plastic here and there? Or metal?
Old Jul 11, 2001 | 08:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The griffin universal fit GM 19x31 won't fit w/o cutting. They also have direct fit radiators as well as Be Cool but the price pretty much doubles.
Give Summit a ring, they'll hook ya up.
Old Jul 11, 2001 | 11:38 PM
Scott_92RS's Avatar
Car: 1992 RS
Does anyone have a pic of one of the generic radiators installed? I am willing to cut a little bit if it is going to save me a few hundred dollars. Thanks!
Old Jul 12, 2001 | 07:53 PM
JoelOl75's Avatar
I had to fab top mounts to hold the radiator and fans and also to tip it back some in the bird as the radiator cap hit the hood. Also if your car has the stock engine oil cooler, you need to find a way to mount the 3/4" return line into the bottom radiator hose (Or some other low pressure area), remove the rubber bumpers in the bottom of the support and use something thinner, and I also cut some material off the top and added a plate of T-6 to hide the chop. There's 1/4" rails on the top and bottom of the griffin where I drilled 1/8" holes for self tappers to hold it all. Going over the top with a support seemed impossible in my case as there's about 1/8" of hood clearence... Also you need a seperate trans cooler.
http://www.angelfire.com/pa4/camaro350/overview Overview PIC
http://www.angelfire.com/pa4/camaro350/closeup Closeup PIC
[This message has been edited by JoelOl75 (edited July 12, 2001).]
Old Jul 12, 2001 | 10:46 PM
Scott_92RS's Avatar
Car: 1992 RS
Your install looks good. If I understand you corretly, the bottom end fits in nicely if the rubber bumpers are replaced with something different. The fan doesnt look like it is too hard to mount. Is there any way you can give me the measurements for the custom brackets you made? Is there anything holding on the front of the piece of aluminium, or is it just attached to the radiator? Thanks, the picsc helped a lot.
Old Jul 13, 2001 | 09:11 AM
scauffiel's Avatar
Here's my install:
http://www.transamtemple.com/modifications/griffin.htm
Click anywhere to get a pop up menu...
Darth Steve
Steve's Trans Am Temple
Old Jul 13, 2001 | 10:07 AM
Scott_92RS's Avatar
Car: 1992 RS
I think I will try the fiberglass method. I like the staighter lines of it. How did you mount the fan?
Old Jul 13, 2001 | 10:15 AM
Locry's Avatar
..test.. sorry
Old Jul 13, 2001 | 03:18 PM
scauffiel's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Scott_92RS:
I think I will try the fiberglass method. I like the staighter lines of it. How did you mount the fan?</font>
Uhhhh... you talking to me?
DS
Old Jul 13, 2001 | 03:30 PM
Scott_92RS's Avatar
Car: 1992 RS
<font face="Verdana, Arial" size="2">Originally posted by scauffiel:
DS
</font>
Yeah, I'm talking to you, you got a problem? J/k. Do you have any suggestions for me if I use the fiberglass method? How would the fiberglass mount to the radiator? Thanks.
Old Jul 13, 2001 | 08:40 PM
scauffiel's Avatar
Nope. Take your time, and do it right. You can either drill holes along the top of the radiator where there is a 1/2" to 3/4" lip and secure the shroud that way, or just make the fiberglass really tight around the radiator top. When it's dry, take it off and put some 3/16" foam inside to make it even more snug. If you're feeling really squirrely, mount your fan first and you can make the shroud form fit around that as well at the same time...
DS
Old Jul 13, 2001 | 09:53 PM
Scott_92RS's Avatar
Car: 1992 RS
Thanks for your help. I'll be sure to post pics of everything when its done (it'll be a while, though).
Old Jul 14, 2001 | 12:58 AM
JoelOl75's Avatar
I'm sorry... I know the 'glass loooks pretty and all, but....
Try something different, as all this work would negligate the reason of getting the 'cheaper' rad.
I mean.. I don;t have the dementions of the brackets off hand, but I will say I threw many of them away trying to get the 'right' fit. I will measure them if you wish... and I even had the drawback of mounting the MAF, and my bracket mounted the MAF and the fan on the pass side (like stock). The glass looks great by the way, but I trust only metal under severe heat under my condit's (vibes and heat.......)
Old Jul 14, 2001 | 07:43 AM
Scott_92RS's Avatar
Car: 1992 RS
I would just be using the fiberglass as a dress-up piece. I would find some way to mount the top of the radiator more securely. Anyone know of the cheapest place to get one of these radiators?
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
gta power
Aug 13, 2015 06:15 AM
