2 Different Super Rams
Old Mar 11, 2005 | 11:40 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Does anyone know or why there are 2 type of Super Rams? My plenum is 2inches tall an others is abour 2 1/4in tall. Even the runners are about an 1/8 shorter. How I know this is because the bottom of the throttle body where the vacum fitting is hits the top of the thermostat housing. The taller plenums don't. I had to use a carb housing and reroute the hose using a flex hose to go to the radiator.
The other question is- is there a difference in HP & TQ between the two?
Old Mar 12, 2005 | 11:28 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
one is for a truck in the other is for camaros/firebirds
Old Mar 12, 2005 | 11:37 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The shorter one was used for LT1's F-bodys. Lingenfelter cut the plenum height down to clear the hood line on the 4th gen cars.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
