Burning Oil... Where ?
Old Jul 14, 2001 | 03:01 PM
Bort62's Avatar
Smokes On Startup as You would expect Of a 160k Mile Smallblock.
Also Smokes When It has been Idleing for a second, and then I drive it off or give it some gas. The Longer it Idles, the More it smokes when I finally "clear it out".
Dosent smoke at RPM, or on Decell Or anything like that. Just in those Two Circumstance. Every once in a While When I nail it at cruise.
The Oil is staying Fairly clean, and I don't have noticeable blowby out the VC's, So I find it hard to Justify bad rings as the Issue. A leaky Intake manifold Would supposedly smoke at RPM as well as after idle.
Leaky Valve seals/worn Valve guides seem to be the Culprit, Am I correct In assuming this ?
I changed the Valvesprings Back when I changed the Cam, But My Local Parts store did Not Stock the Valve guide Seals, So I was Not able to change those (Time constraints on getting the Motor back Together). I have a feeling My messing around with them Caused the already poor Stock Seals to become essentially ineffective.
Does it sound like This could Be Cause For my greif ?
Thanks.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jul 14, 2001 | 03:33 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You didn't do the seals while you had the chance?? Shame..shame
That sounds like a good place to start.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Jul 14, 2001 | 04:22 PM
Bort62's Avatar
Yeah cept I don't have an air compressor anymore...
Old Jul 14, 2001 | 04:55 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
You have mail...
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Jul 14, 2001 | 05:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
<font face="Verdana, Arial" size="2">Originally posted by Bort62:
</font>
Guess this wouldn't be a good time to tell ya about using a little bit of nylon rope would it?
Old Jul 14, 2001 | 06:11 PM
Bort62's Avatar
Oh I know all about that, Pain In My *** is What that is
Reader's ride -&gt; My Ride
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Logan Bryant
Sep 23, 2015 06:51 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
