Wtf???
Old Mar 12, 2005 | 07:32 PM
BlackMagic's Avatar
Car: 1986 Firebird
Wtf???
Today get in my car and go to turn on the headlights and parkinglights, and only the headlights come on! I first noticed because my gauges would not light up, so i tested the blinkers and they worked. So what happened. Did the rocker switch go out on the parking/taillight/interior side, and have to get a whole new switch or what?
Old Mar 12, 2005 | 07:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Tail light fuse
Replace it, and then figure out why it blew; or figure out why it ble before you replace it, if you don't want to keep buying fuses. Probably a chafed wire somewhere, or a bulb in the socket wrong, or a damaged socket, or hacked wiring (aftermarket add-ons, etc.)
Old Mar 12, 2005 | 07:41 PM
BlackMagic's Avatar
Car: 1986 Firebird
do you know which fuse number that would be.
Old Mar 12, 2005 | 07:47 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
It's labeled on the fuse panel under the dash.
Old Mar 13, 2005 | 12:31 AM
BlackMagic's Avatar
Car: 1986 Firebird
you cant read the labels underthe dash, jsut numbers
Old Mar 13, 2005 | 02:48 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I sure have labels
Old Mar 13, 2005 | 04:46 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The fuse box cover should have a circuit description for each fuse number.
Each fuse has test holes on top, using a test light probe the holes, if one side has 12volts, and the other doesn't then the fuse is blown. If there isn't any voltage at either test hole then the power to that circuit isn't enable i.e. key on/run, or fused further back like the fusible links at the starter, or battery.
Keep us posted.
Old Mar 13, 2005 | 09:23 AM
BlackMagic's Avatar
Car: 1986 Firebird
Alright guys, yall are a life saver. I had checked the fuses quickly once, but must have missed it. Yall were right though, tail light fuse. THanks guys
Old Mar 13, 2005 | 10:02 AM
Vader's Avatar
Just for the next time this happens, save this photo:
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
