Does anyone make a 1 piece seal, externally balanced 400 block?
Old Jul 15, 2001 | 03:01 AM
Dan87IROC-Z's Avatar
I am looking to make a 377, so I will need one that can use a 350 mains for the 3.48" stroke, with an externally balanced crank and a 1 piece rear seal. I didn't see one in Jegs, Summit or Scoggin Dickey, but does anyone know where I might be able to get one?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 15, 2001 | 10:01 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Your best bet would be to get the aluminum bracket that goes on the back of a 2piece seal motor and allows a 1piece seal to be used. GM should have them. Since your using a 350 crank, it will be internally bal.
Old Jul 15, 2001 | 10:04 AM
ede's Avatar
ede
not sure about the 1 piece seal but gm makes some preformance blocks as does some aftermarket manufactures.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 15, 2001 | 04:08 PM
Box of Rocks's Avatar
Dan,
I've been busy, but I'm back.
Moroso makes a conversion to the 1-piece seal in kit form. It's sold thru Jeg's and is very low cost.
Jegs also sells the different sized bearings to make a 400 into a 377.
Any 350 SBC reciprocating assembly should internally balance.
Good luck.
BOR
midge54
Dec 27, 2019 04:14 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
