HOW DO I GET OIL SENDING UNIT OUT HELLP!!!!
Old Jul 15, 2001 | 10:28 AM
nativ's Avatar
I bought a socket for s/u 1/16 & 1 extra deep but could not get it on becouse unit is to close to frame/body. then I went and got a 1 1/16 combo wrench but the body of the s/u in the car is larger than the box end of wrench. Cannot get to it from the top and cant get open end on from below. Is the oem unit a diferent size nut than the replacement? and will i have to lift the car to do this. help! its sunday and this is my daily driver I want to avoid damage to motor. any one know if you can rent a test unit (mechanical)from discount aouto parts or aouto zone. thanks.
Old Jul 15, 2001 | 12:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If you can get a set of pliers/visegrips on it, it should come right out.
They aren't very tight usually.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Jul 15, 2001 | 01:32 PM
un4givin89's Avatar
12 guage might work??
Old Jul 15, 2001 | 01:47 PM
nativ's Avatar
Im begining to think that would work quite well. I hate it when this S**T happens.
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:
12 guage might work??</font>
Old Jul 15, 2001 | 05:30 PM
nativ's Avatar
SUCCESS!! I got the new one in after putting it up on jack stands getting unerneath and using fing channel locks on it. The oem was a 1 3/16 replacment was 1 1/16. Pressure seams to be fine. about 30psi at idle and 45 driving. old unit was leaking. thanks again for your help.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
