faster power windows
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
is thier anyway without extensive work, to make my damn powerwindows move faster, i swear a slug can crawl faster..
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Cleaning and lubing would probably also help--bottmline is that they're slow.
JamesC
JamesC
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I can't believe nobody has tried a retrofit using a different motor or something yet. Hey, Grand Prix windows fly up and down, somebody should try popping off the gears of each and swapping it, then bolting it up to the existing window unit. Or anything, hell, just somebody figure this one out for us! lol
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
I can't believe nobody has said something about this window post being in the general engine board.
https://www.thirdgen.org/techbb2/sea...der=descending
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
All you need to do is grease the slides. I mean damn they are 23 years old atleast. I spread some chassis grease on my 82 and damn did it speed it up!
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
How about placing a "Boost-a-pump" in the power window circuit? If it speeds up the fuel pump, why not the window motors too?
-Tom
-Tom
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Is it possible to rebuild the motors?
I know you can replace the carbon brushes in the cap, but what about the entire motor assembly? Is it worth it? can new parts be obtained?
Car: 1982 Trans-Am
it might set you back $60....
Up here, in the land of the-unfair-auto-parts-pricing, a cheapo reman unit from Napa was $111.
$220 to get new power window motors is kinda high for me. I'd rather rebuild, and learn from it if possible... I'm thinking of rewiring (since mine stopped working rather abruptly), and checking switches etc. Then rebuilding and greasing tracks to get them up to par.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
There was an article i read a while back about how to fix a powerwindow motor in the car but it involved a new one and switching parts.
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The switches can be taken apart and cleaned up. Lots of junk can fall down into them over the years. There are two copper sliders that are held on the contacts by a spring. One for each. Use electrical contact cleaner. If they still look tarnished then clean them up with 400 grit sandpaper. Reassemble.
Grease up the window tracks can help a lot too. Usually the bigger cause of this problem than any other.
Rewire it as a last resort. Don't go butchering up the factory harness unless it needs to be replaced. Learn how to use a multimeter and learn to love it. It will come in handy for many things.
Car: '86 Berlinetta
the problem is that the windows are F-ING HEAVY!
I remove 2 - 3 windows a day in my auto body class... none of the other cars have that heavy of doors, I swear!
The window motors will work for our cars too, and might be slightly better (just because they're newer) but they wont make them go up really fast like in the luxury cars.
If you really want to speed it up, grease up the tracks well (white lithium, no spray on grease), and use a thicker gauge wire to the power windows motor.
That's about all you can do short of switching to manual windows (in which case, I've got manual setup that I'll trade you if it comes w/ the wiring too hehe)
Sorry for the misunderstanding, I meant the drug taken as psychiatric medicine
JamesC
JamesC
Car: 1989 C4
Axle/Gears: 307
Nearly all GM window motors are the same, so there isnt a magic wonder motor that will run 2x faster then another. Like mentioned in the posts above servicing the motors will help quite a bit along with replacing/lubing the slides and inspecting the guides to make sure 20 years of crap isnt stuck in the guide rails. Ive been wanting to service my windows in the Camaro and replace the burnt PS motor but dang I hate screwing with windows even when I'm paid to do it.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'm going to be reconditioning my new doors before they go back on, with new motors, lock solenoids, greased tracks, sound deadening, new locks, etc.
Hopefully I'll never have to do it again.
What do you use to put new motors in? I've heard of a bolt and nut, but that doesn't look like it would fit. I don't have one of these sumo riveters laying around!
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
nuts + bolts + locktite...
dont forget that last bit...... skip the locktite, and a year from now, you'll be doing it again... (or a month.. depends... lol)
Car: 91 Z28, t-top, 5.7l ZZ4 rebuild
Engine: 5.7L TPI
Transmission: 700r
Lazy... er Jim
Car: '86 Berlinetta
Originally posted by Brazen
I guess that goes for sticking electric door locks as well? My driver's side lock will not engage (lock) fully using the buttons, although the Passenger side works like a charm. I guess I'll have to spend a fews hours one weekend, and sevice the doors for windows and locks.
Lazy... er Jim
Lazy... er Jim
If you want to find out if it's the gauge of wire that is the problem (which could just be a bandaid to the real problem, but doesnt hurt) then do it without all the plumping through the door grommet and stuff first. Then if it makes a noticeable difference, take it apart, plumb it through the grommet, solder it, and you're good to go.
The hardest part of the whole task is taking the door panel off (lol)
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My windows were slow, and my passenger side window kept getting slower and slower. Well one day it just stopped. It turned out it was just the switch, but the window rolled up much faster. Even faster than the driver side now. So I replaced the driver side switch and it also increased it's speed. My switches must have been really going bad.
I am happy with my window speed now
Engine: 5.7L TPI
Transmission: 700r
Jim
Car: '86 Berlinetta
Originally posted by SSC
Actually white lithium grease get hard and sticky after a few months. Vasoline works the best.
Vasoline... that's one of ***'s gifts to earth... great for a ton of things... cars, boats, girlfriends and water slides (dont ask
) Member
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
what dose it mean when you have to kick the door to get the window to work???
WOW could I touch that one but I won't.
The window in our cars suck. I have owned my car for a long time and the windows did not go up any faster new as they do now just one of the bad things about our cars. We have to live with it
Engine: 5.7L TPI
Transmission: 700r
Jim
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
lol, the inside of the door, near the front(basicaly right on top of the moter) is where I have to kick
Like stated above, cleaning and lubing the channels, gear, guides etc will help a good bit. For me, I still was not satisfied. I replaced both window switches after tracing down a voltage drop of almost 1.5V if I remember right - all in the switch. They move pretty good now
Car: 91 Camaro Vert
Originally posted by HalfInchWrench
Could try Astroglide but I think it is just for mini-vans.
lmao..
i think im just going to add in 2 relays in each kickpanel, and have them power the window motors.... should work better then the "power thru the chassis, thru the switch, back thru to the door" setup we have now.....
edit:
if nothing else, it'll allow me to run any SPDT momentary toggle switch i want later on...
Engine: 5.7L TPI
Transmission: 700r
Originally posted by MrDude_1
lmao..
edit:
lmao..
edit:
Jim
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Re: faster power windows
Basically guys, if you want faster windows...
1.Replace your brushes and the worn springs regardless of condition.
2.Clean off any old lube off the tracks and grease them with wheel bearing grease/ white lithium/ vasoline, etc.
3.Check/clean out your buttons and replace if nessesary
Whoever said put crank windows in, has a screw loose in their head. I spent 3 days converting my car to all power with donor parts. Those cranks cause more problems than the power. I've almost totalled my car trying to roll down my pass. window with manual windows.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
It's probably a bad window motor. Thats how electric motors tend to act when they're worn out. It's basically the same thing and hitting a stuck starter with a hammer to get a car to start.
Car: 89 WS6 FORMULA
Engine: LB9 305
Axle/Gears: 2:73 posi
you can buy a greasless lubricant from your local parts store,spray it on the side rubbers and tracs it made mine faster and without the greasyness of other lubes.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
