what is the sensor on the drivers head between the 1st and 2nd plug
Old Jul 15, 2001 | 07:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
i am replacing all the sensors on my new motor swap and need to know what the sensor is that is located between the 1 and 2 plug on the drivers head of my 91z28 350 tpi motor
Old Jul 15, 2001 | 07:45 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
temp sending unit...
but it's actually #1 and #3 plugs...
KAM
[This message has been edited by thunderstick (edited July 15, 2001).]
Old Jul 15, 2001 | 07:58 PM
BOTTLEDZ28's Avatar
Transmission: A4
so the coolant fan switch is on the passenger heads the the temp sending unit is on the drivers head. what does this snesor cost from a parts store
Old Jul 15, 2001 | 08:50 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
about 10 bucks..
most of the sensors for 3rdgens are anywhere from 10-25 dollars, O2 is about 50, MAf is the most expensive at 100-120 and the EGR is 70 at the GM dealer
Webmaster: www.IROC-Z.org
Old Jul 16, 2001 | 12:43 AM
92fire-audio's Avatar
Is this sensor the same on the L03 block engine too? If so, I guess I can stop worrying that my fan sensor is broke. The temp gauge still gets a reading but I was never sure if it was right after I changed exhaust.
Does the fan sensor control anything other than the fan in the ECM? I have the fan wired always on so that doesn't matter...
THanks
Old Jul 16, 2001 | 01:04 AM
Engine: 305TPI
controls nothing else except turning them on/off..
the gauge sensor (1-3 spark plug) will work on pretty much any engine, it's standard chevy
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
timonator
Aug 11, 2015 09:56 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
