Remove the oil pan with the engine in the car?
Old Jul 13, 2001 | 02:19 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
hey,
My '83 automatic car with the origional/stock (afaik) engine. Can I pull the oil pan off with the engine and tranny still in the car?
I'm having some problems and want to rule out or confirm lower end trouble before yanking the engine.
If the pan can be dropped and removed with the engine in the car, are there any tricks to make it go smooth (relatively)?
any insight is appreciated
thanks
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
[This message has been edited by clemsparks (edited July 13, 2001).]
Old Jul 13, 2001 | 02:44 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
not without some lifting of the motor.
Old Jul 13, 2001 | 03:50 PM
Synergy's Avatar
Yes he's right. You have to lift as high as you can and it will take some maneuvering around the get the pan to clear the rods and counterweights on the crank. You might even have to bump the engine a few times to move the position fo the crank if it doesnt come out after a few tries. And dont forget to take off the dist cap. IF you lift it up too high it will crush against the firewall.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Jul 13, 2001 | 04:56 PM
Omar's Avatar
Like everyone else said, Raise it several inches and your pan will come off easily. No matter what, I would remove the distributor.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 13, 2001 | 09:27 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i removed my distributor and raised the engine up about 6"
when it was that high I had no trouble getting the pan off and on..
Webmaster: www.IROC-Z.org
Old Jul 16, 2001 | 07:08 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Thanks for all the advice.
I pulled the engine anyway this weekend. Turns out it was a bent rod . could've been worse
thanks
Clem
maroe624
Apr 16, 2017 08:29 AM
B_Dubya
Aug 26, 2015 05:09 PM
MY87LT
Aug 17, 2015 08:43 AM
3rdgenparts
Aug 8, 2015 07:09 PM
gwade12
Aug 8, 2015 08:17 AM
