How much is a stock 305 worth?
Old Jul 14, 2001 | 10:55 PM
gravitar's Avatar
I apologize if this is far off topic for this forum, but I'm not really sure what my motor is worth! Its a totally stock 305 in an '86 Z28. 108K miles, in very good condition. It has TPI, which I plan on keeping. I really only want to sell the long block, water pump, and exhaust manifolds.
How much should I ask for this motor? I really haven't checked the paper yet, to see what people are getting. I've got a strong 350 waiting to go in, and since I'm stripping down the body for painting, I figured I'd empty out the engine compartment so I could get that too!
Old Jul 14, 2001 | 11:18 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
400/500$ running!
SSC
Old Jul 15, 2001 | 12:30 AM
iroc5speed's Avatar
anything is worth whatever someone will pay for it =). sorry for being a smart@$$. If I were you I'd try to sell it on ebay.
Old Jul 15, 2001 | 09:29 AM
gravitar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SSC:
400/500$ running!
SSC
</font>
Wow, that much?! It runs good, I'll leave it together so that whoever wants it can see it run. I'd be really happy if I got $400 for it.
I never thought about putting it on ebay.. I'll take a look and see what people are getting for motors there.
Old Jul 15, 2001 | 10:04 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
<font face="Verdana, Arial" size="2">Originally posted by gravitar:
</font>
I just sold a 4 bolt, pre-85, virgin 350...block only (No guts/heads, etc.) for $250.00....
$400.00 has a nice sound to it..
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 15, 2001).]
Old Jul 15, 2001 | 11:21 AM
Bort62's Avatar
I wouldn't Pay that Much For it, Damn
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -&gt; My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jul 15, 2001 | 12:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
A 108k mile 305 Longblock? $400.00? Good luck. I don't think I'd pay $400.00 for a 108K mile 350 longblock, no would many other folks.
Realistically(did I spell that correctly, doesn't look right?)I don't think you're going to get much more than $100-$150 for it.
If you keep it in the car and running, let someone check it out (compression, etc), you may get more....
Old Jul 16, 2001 | 07:48 AM
gravitar's Avatar
Yeah, I was thinking $150 would be more realistic. Especially since I need to keep just about everything.. pulleys, brackets, I probably even need the oil pan!
They don't look like they go for much on ebay, which isn't surprising. How much would you pay for a motor from across the country, that you couldn't even see run?
I'll probably just list it in the local paper for $150. I need to put in an ad for my S-10 cap anyway!
Old Jul 16, 2001 | 08:42 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I gave away a 1986 305 shortblock just this spring. It turns out to be worth less than any other 305 because its a crossover year. It sports a 1-piece rear main seal crankshaft, but doesnt have the roller cam. Some of the 1986 engines dont even have the bosses cast into the block for the spider that holds in the lifters.
If it is a good, running 305, keep it a good running 305 and sell it as a complete long block. That is the only way I can see it being commercially worthy of selling. Someone might want to pop it into their S10, perhaps.
Thats what I am going to do with my 305 next spring. I'll sell it complete including the carb and computer, once I take the prospective owner on a thrill ride down a country road.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Jul 16, 2001 | 09:37 AM
Stuart Moss's Avatar
I too plan on replacing my 305 with a 350. I do not expect to get much for it (101K miles) even though it runs without any leaks or problems. A couple/few hundred dollars I think would be a realistic amount.
Since the amount I'd get would be so little, I think that I will just keep it and use as a spare in case the main engine (350) needs to be removed for whatever reason. Then, I could just drop this one back in while I work on 350 at my leisure.
Just a thought.
Old Jul 16, 2001 | 09:53 AM
84Berlinetta305's Avatar
You should al least be able to get $200 -$300 out of it. I sold my 84 2.8 for 300, 150 is way too cheap in my book.
Old Jul 16, 2001 | 11:29 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well I called a couple of the junk yards around town this morining and confirmed my quote of 4/500$ And they said, for a running 305 your looking at 500$ For a running 350 they wanted 650$ thats running no smoke and good oil pressure. Of course thats carbed with manifold.
SSC
Old Jul 16, 2001 | 11:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's a world of difference between a "running motor with no smoke and good oil pressure" from an established business and a "used long block with an old water pump and some exhaust manifolds" from a random member of the general public. Also, keep in mind that the junkyard warranties their parts to the buyer, i.e. if it's not satisfactory as a running motor the buyer can keep exchanging it until he gets one that is. Are you going to do that for whoever buys your old motor? Then yours isn't worth as much as theirs. Rather, yours is a core, not a running motor. Then, remember that yours is not a roller block; demand for worn-out non-roller 305s with 416 heads on them is about as strong as demand for snow in Antarctica.
I'd say that somewhere between $100 and $200 would be the most it's possibly worth, including shipping, and you're not likely to get even that much for it unless you're real lucky. I've thrown motors like that in the garbage because they weren't even worth the trouble of hauling to the scrap yard for their cast iron weight.
ICON Motorsports
[This message has been edited by RB83L69 (edited July 16, 2001).]
Old Jul 16, 2001 | 01:18 PM
Bort62's Avatar
<font face="Verdana, Arial" size="2">I've thrown motors like that in the garbage </font>
That Must be Quite a Suprise For the Garbage Man
jhawkeye
May 25, 2022 06:33 PM
Grant2k
Jul 10, 2018 04:01 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
