Smoke on startup??`
Old Jul 16, 2001 | 07:58 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
Smoke on startup??`
My 1990 IROC puffs out some blue smoke upon starting it in the morning or after a prolonged stop somewhere (parking lot, etc). I have heard that it could either be a problem with the piston rings or the valve cover gaskets. Is there any easy way to figure that out aside from getting a compression test and leakdown test?
Old Jul 16, 2001 | 08:17 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
nah,it's your valve guides / valve stem seals..
gotta pull the heads off for that one, unless you want to change the seals with the heads on the car (not fun)
no worries, it's a standard SBC problem, they've all done is since the SBC was an engine.. it's probably fixed in the newer engines but the older ones always smoked a bit when you hit the key
Webmaster: www.IROC-Z.org
Old Jul 16, 2001 | 08:21 PM
BlackZee's Avatar
Chevy smallblock trademark, keeps everything good and lubed!
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
