Distributor Swap QandA
Old Mar 17, 2005 | 12:26 AM
F-BirdBauman's Avatar
Car: 1987 Firebird
Engine: D.Remmington 415 Small Block
Axle/Gears: 4.10
I have the LG4 305 and it has a strange type of HEI Distributor in it with an external coil, the coil has two dual wire harness plugs that attatch to the top of it along with the main coil (spark plug type) wire. I would like to put the standard internal coil type HIE in the car, how and will i be able to do this?
Old Mar 17, 2005 | 06:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's nothing "strange" about the later-model style of HEI that I know of. It's possible to swap them; but there's no particular reason for putting the old style one in there. It's not any better in any way.
They don't have the same small-signal wiring, that carries the RPM signal to the computer and all that. It would require considerable hacking on the wiring, which is probably not a good idea.
What is it that you want to accomplish by doing this?
Old Mar 17, 2005 | 08:36 AM
Car: 1987 Firebird
Axle/Gears: 4.10
A cheaper way to upgrade the coil.
midge54
Jan 29, 2017 07:00 PM
LittleFranks
Sep 17, 2015 12:22 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
