help what sensor is this
Old Mar 17, 2005 | 01:47 PM
zeek's Avatar
Car: 1986 firebird trans am
ok i cant give much info being im not exactly sure so hope you guys can tell me what sensor this is anyways.
i need to know what is on the intake manifold infront of the carb?
this is on a 86 lg4 if that helps at all
Old Mar 17, 2005 | 01:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The canister purge thermal vacuum switch is mounted directly in the manifold, and has 2 large vacuum lines going to it; and the EFE thermal vacuum switch (with 2 small vacuum lines) and the ECM's coolant temp sensor (with 2 wires) are mounted in the water outlet.
Old Mar 17, 2005 | 07:59 PM
zeek's Avatar
i figured it out it was the coolent temp sensor i went to the auto part store the other day and they gave me the wrong sensor and i couldnt figure out why until but i did and now iv got the write part hmm wonder if this engine will come back to life now
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
