security lug nuts @#$%$##
Old Mar 18, 2005 | 05:31 PM
Sgt.D's92RS's Avatar
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
Went outside to change some brake pads. This is the first time I had to change them. I start removing the lugs and low and behold there sits one of them security type lug nuts that require a key type adapter. I bought the car used so I do not have the
key adapter. Any suggestions on how to remove it without the
adapter. I'm thinking vice grip maybe?????
Old Mar 18, 2005 | 05:38 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Weld a big nut to the end of it.
If you dont have a welder handy, cold weld it with those $6 kits you can get from the parts stores.
Old Mar 18, 2005 | 05:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've always had the best luck drilling out the stud and replacing it.
Old Mar 18, 2005 | 06:42 PM
25THRSS's Avatar
Take an old socket and hammer it over the top of the locking lug nuts. They shouldn't be torqued down enough to cause it to slip. I've done it and it works.
Old Mar 18, 2005 | 06:51 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
that's what I did. I believe it was an 18 or 19mm, but it came right off.
Old Mar 18, 2005 | 07:40 PM
86TA305Ga's Avatar
Car: 1986 Trans Am
Engine: LG4 305 (The wheel's still spinnin but the mouse is dead!)
Transmission: A4 Automatic (Little Rusty Wheel) heh
Make sure you use a good socket like Craftsmen, they will replace it for free...
The socket is a 20-21mm that will bang onto it. I've had 3 cars with this problem and the socket hammer trick works fine.
If you can't succeed, take it to a GM shop and they will do it in most cases for free.
I also suggest throwing those lugs away and getting 4 regular lugs from a junkyard for it.
My final permament soultion is a $79 kit that has keys for most vehicles, not the key itself but the bang on reusable sockets and such.
Here is the Kit and Part Number:
http://www.toolsource.com/ost/produc...8TKTJBMB1C83C9
Manufacturer: AJ Manufacturing Co., Inc.
Manufacturer #: 400
ToolSource #: 50397
Here are the details:
Removes and replaces Ford, GM & Chrysler wire wheel hubcap locks on 1978-1998 vehicles without key.
Also removes most factory & after market lug locks.
*It claims a its for an impact wrench but a good socket wrench and extension will work 99.9% of the time.
Upon looking for it again, I noticed a kit that will work for GMs for less:
Kit Price: $38.95
Details:
This set will remove and replace most hubcap locks on GM, Ford, Chrysler and aftermarket wheel lug locks without factory original key.
Hope this helps...
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
Sep 30, 2015 01:50 PM
gord327
Sep 29, 2015 10:18 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
3.8TransAM
Sep 27, 2015 08:37 PM
