EGR valve
Old Mar 19, 2005 | 12:11 AM
rayvendawn's Avatar
Car: 1983 Z28 Camaro
Engine: 305 poop
EGR valve
What happens if the egr valve doesn't work at all? What does it do and whatnot?
Old Mar 19, 2005 | 05:17 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: EGR valve
Introduces small amounts of exhaust gases into the fuel mixture, reduces cylinder temperatures, and decreases nox emissions.
That doesn't mean that it'll run hotter because the cooling system can handle the extra heat, but at idle the thermostat may stay open longer.
Old Mar 19, 2005 | 07:05 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
EGR is not open during idle, so it's operation has nothing to do with the temp during idle.
EGR is only enabled when you're going over 35 (I believe) and when you've been cruising at low throttle ( some percentage i forget) for a certain amount of time. The DIY Prom guys know the specifics.
Old Mar 19, 2005 | 09:06 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
You're right I forgot about that, been up all night replacing the nose, reinforcement, and left fender. That frontend has a boat load of screws, and bolts. The headlights were a pain.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
