Is Methanol safe to use as water remover ?
Old Jul 17, 2001 | 08:58 PM
GTA88's Avatar
I can't find a single "dry gas" product anywhere that has Isopropyl Alcohol, which is supposedly totally safe for cars. All I can find is stuff that has absolutely no ingredients listed, or has methyl alcohol or methanol as the main ingredient. If methanol is not safe for our cars, where can I get some of the old-fashioned isopropyl "dry gas' ? Assuming it is safe.... Once I dump this dry gas into my tank, it could be in there for a few months, so I want to be careful. btw my car is TPI.
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Jul 17, 2001 | 09:18 PM
Like a ROC 89's Avatar
Check the first aid isle at Jewl/Osco or Dominicks. Isopropyl alcohol 90% $0.99. But 10% of the 12oz bottle you just emptied into you tank is water??? I dont know???
Old Jul 18, 2001 | 03:44 PM
GTA88's Avatar
bump.
Old Jul 18, 2001 | 09:00 PM
Xenodrgn's Avatar
Let it sit for now, when you go to drive it whenever first see if it -needs- it, then if it does just add the bottle and get rid of that tank of gas as fast as possible... or just live with a little water in your tank until you can fill it up with good stuff, I wouldn't let it bother you too much.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
