350 heads on a 305
Old Jul 18, 2001 | 12:05 PM
fourspeed's Avatar
350 heads on a 305
will they work? any problems with them being installed on a 305 tpi, any hints or suggestions
Old Jul 18, 2001 | 12:15 PM
sb406camaro86's Avatar
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
will bolt on but compression might be pretty low.
Old Jul 18, 2001 | 12:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Umm it really depends on what size valves and size of the combustion chambers. Anything higher than 64cc will reduce the compression and you will be kicking yourself. And some valves wont clear unless you bored the block out. Of course to make ant soild suggestion we need to know what size heads casting numbers will help detremine that and what mods have been done to the block
"Ie" bored over with dome pistions.
SSC
Old Jul 18, 2001 | 02:07 PM
ATOMonkey's Avatar
This has been beat to death. Check the archives, or do a search.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 19, 2001 | 08:36 PM
Gerald Jackson's Avatar
<font face="Verdana, Arial" size="2">Originally posted by fourspeed:
will they work? any problems with them being installed on a 305 tpi, any hints or suggestions</font>
You can put the 350 heads on a 305, but you
should use 350 head gaskets. I did this with
305 gaskets and had a heating problem, then I
put the 350 gaskets on and the heating problem went away.
82 cross-fire, 410 gears
700r4
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
