gas gauge
Old Mar 22, 2005 | 08:26 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
gas gauge
When i hti the brakes, my gauge goes all the way to e. When i accelerate, it goes to where the rightg amount of fuel in, when i turn it goes to almost e whats the problem?
Old Mar 22, 2005 | 08:29 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Gas sloshes around in the tank. Mine does the same thing. Some newer cars have an "Electronically Stabilized" gas gauge. Personally, I think that is overkill........ Could be that your baffles are gone/broke loose/never installed..... Not really a "problem", just an annoyance.
Old Mar 22, 2005 | 09:25 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
If it does that abruptly, then you may have a bad connection in the dash. The reason I say dash and not the tank is because the clutch movement is felxing the dash area possibly causing a bad ground or connection. The gauges just plug in, nothing really keeps them tight so it might be worth checking. Pulling the dash is no big deal, I've had mine out so many times that I put a zipper on it.
Ghettobird52
Jul 5, 2024 11:18 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
