sensors for engine removal
Old Jul 15, 2001 | 09:04 PM
camaro6spd's Avatar
I need a list and locations of all the sensors that need to be taken off the engine for the block removal. I don't know what the names of them are and am not sure of everything I need to remove. Things like the CTS and O2 sensor. Thanks I have a 1987 305 TPI. Also anyother things that I should remove before I pull the engine.
Old Jul 15, 2001 | 09:08 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
hey man..
here we go:
<ul>[*]under plenum there is the MAT and EGR[*]coolant temp sensor[*]sensor beside the CTS on the front of the block[*]temperature switch on the driver side between cyls 1 and 3[*]oxygen sensor on driver side exhaust manifold[*]distributor connectors[*]fuel injector plugs[*]throttle body linkages[*]throttle body vacuum hoses (one under, one on pass side)[*]9th fuel injector plug[*]knock sensor[*]starter connections[*]spark plug wires[*]ground on rear of the passenger side head[*]AIR system[*]water pump hoses[*]possibly the engine cooler hoses if you have rpo KC4 in your glovebox[*]AC connections, one on the front of the AC compressor and one on the rear[*]alternator wires, ground on the rear and it's plug[/list]
anyone else? i don't think i missed any, heh..
good luck man I disconnected my O2 sensor when i started to lift my engine cuz it was too hard to reach when the motor was sitting in the car..
ttyl
Colin
Webmaster: www.IROC-Z.org
Old Jul 17, 2001 | 05:16 PM
camaro6spd's Avatar
Thanks, you did not mention what the other sensor beside the CTS Sensor was, I need to keep things short the label the wires with. I need the location and the name. Thanks
Old Jul 18, 2001 | 07:10 PM
camaro6spd's Avatar
ttt
Old Jul 18, 2001 | 08:07 PM
Engine: 305TPI
it's called the Cold Start sensor, i checked in my factory assembly manual for you
Old Jul 20, 2001 | 09:09 AM
camaro6spd's Avatar
thanks you very much sir.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
